Autopilota Raymarine con Gyroplus
francesco72 Offline
Registrato: Jan 2011 Online
Messaggio: #221
Colibrì, ti ho mandato una mail. Intanto quelli di Seymo, che leggono il forum, mi hanno detto che, loro malgrado, sono obbligati a 'file a lawsuit against you and decide justice'. Ma cosa ho commesso di illegale se non testare un loro prodotto regolarmente acquistato? Le foto dei millefori parlano eloquentemente del loro prodotto. Mah ...
(Questo messaggio è stato modificato l'ultima volta il: 11-11-2013 19:14 da francesco72.)
11-11-2013 18:20
umeghu Offline
Messaggio: #222
You should explain to the SEYMO management that NO LAWSUIT can be planted against the Forum or the Forum's partecipants.
There was only a deep and sustantiated discussion on malfunctions on some of SEYMO RAY GYROs; as a matter of fact 11 out of 12 Gyros were found with the same and dangerous defects. You also opened one unit (yours) and found what the inside elements were.
It would be nice to have a lasuit planted, so it would be possible to plant a counter lawsuit:
A) for attempting to the lives and health of EUROPEAN clients and
B) for selling in EUROPE a good not responding to what described in the advertising.
Also, the fact that the clients should bear all the costs for returning the product to the manufacturer and have an exchanged one back, is VERY questionable, as this action is due to a product fault and to the supplier's responsability.
For last, there could also be ground for a 'class action' against SEYMO.
In Italy one would talk about 'Hay's tail'.
It is though true that I wrote them tellling that the situation (faulty products sold over the internet) was damaging their image.
I also suggested them to inquire their purchasing/manufacturing/testing procedures as 11 products out of 12 make a very large Quality Assurance Problem - Non Compliance.
(Questo messaggio è stato modificato l'ultima volta il: 11-11-2013 20:07 da umeghu.)
11-11-2013 20:01
francesco72 Offline
Messaggio: #223
Grazie a tutti per il supporto che interpreto come un affettuoso abbraccio. Le mie intenzioni sono chiare quindi non ho nulla da temere.
Piuttosto, questa sera, andró a ritirare il prototipo, Vorrei darlo a Colibri ma non riesco a mettermi in contatto. Maró ha fretta di averlo, ma per assemblarli ho bisogno di qualcuno che lo testi. Io non ho tempo. Chi si offre come beta tester e si prende la briga di darci l'ok o il ko? Offritevi solo se siete sicuri di poter fare il test a breve (meteo permettendo). Appena avró l'ok il tempo di avere i pezzi da Farnell (1 o 2 giorni) + 1 giorno per l'assemblaggio e spedisco.
11-11-2013 22:35
colibrì Offline
Registrato: Oct 2008 Online
Messaggio: #224
Ciao Francesco, come già detto in precedenza sono a disposizione per fare il test del nuovo gyro, ti ho inviato il mio recapito.
Purtroppo il meteo adesso non mi consente di fare prove, spero per il prossimo fine settimana.
11-11-2013 23:32
st00042 Offline
Registrato: Aug 2010 Online
Messaggio: #225
Ciao Francesco,
io purtroppo ho la barca in Sardegna e per problemi familiari non ho al momento possibilità di raggiungerla (mi è saltato anche il ponte di Tuttisanti).
Rimango comunque disponibile per l'acquisto del prodotto finito.
lunar1960 Offline
Registrato: Sep 2008 Online
Messaggio: #226
Io lo potrei testare questo w.e., però ho bisogno di mare mosso per dare un responso valido, dato che il Seymo, una volta superato il problema del ritardo, và alla grande. La scorsa Domenica 3 Novembre, sono uscito con 30 nodi di scirocco (c'era una mareggiata a Sistiana che impediva alle barche di uscire per la Rilke), ho volutamente tenuto il pilota con le onde sia al giardinetto che al mascone e teneva la barca in modo eccellente.
br1 Offline
Registrato: Aug 2007 Online
Messaggio: #227
La fortuna ci assiste sull'Italia c'è una forte perturbazione potrai fare tutti i test
Io mi prenoto per l'acquisto
Ciao Br1
12-11-2013 03:56
francesco72 Offline
Messaggio: #228
Ok, domani spedisco a Colibrì. Ricordatevi, se non mi sentite più, di mandarmi le arance ... olè 42
Vi lascio un nuovo video:
http://www.youtube.com/watch?v=LB6yAgrw788
... anche questo non è male:
http://www.youtube.com/watch?v=NHCimcrKSXs
(Questo messaggio è stato modificato l'ultima volta il: 12-11-2013 06:04 da francesco72.)
12-11-2013 05:58
Buc@niere Offline
Registrato: Mar 2008 Online
Messaggio: #229
Solidarietà a francesco72. Considera quanto scritto da umeghu, tutte considerazioni sacrosante.
Nel frattempo io aspetto a mandare indietro il mio, 70€ di spese di spedizione non sono poche.
12-11-2013 07:00
umeghu Offline
Messaggio: #230
La causa non potrebbe che essere civile, quindi NADA NARANJOS.
Inoltre nel codice italiano esiste il reato di 'Causa temeraria' cioe' di cuase campate in aria, fatte sapendo che non esiste un fondamento, ma , appunto, fatte per altri scopi.
Tranqilo, Hombre!!
12-11-2013 12:11
francesco72 Offline
Messaggio: #231
@Colibrì, spedito stasera con DHL ... si monta con il filo verso il basso. Buon TEST e facci sapere presto.
[Questo contenuto non e' visualizzabile da te Ospite. Se vuoi vederlo, REGISTRATI QUI .[/hide]
(Questo messaggio è stato modificato l'ultima volta il: 13-11-2013 05:15 da francesco72.)
13-11-2013 01:27
faberroma Offline
Registrato: Dec 2008 Online
Messaggio: #232
É piccolissimo! Fantastico, per installare il seymo ho dovuto tribolare mica poco.
Quanto é spesso?
F
13-11-2013 05:46
francesco72 Offline
Messaggio: #233
Penso al massimo un centimetro.
13-11-2013 14:54
tetescio Offline
Registrato: Sep 2007 Online
Messaggio: #234
devo essere sincero,il mio Seymo sembra funzionare bene,ma mi fido molto di più di quello ADV,se decidi di produrlo e venderlo sarei interessato!!!
B:V.
Lorenzo
13-11-2013 15:14
faberroma Offline
Messaggio: #235
Ottimo, posso metterlo dietro i cuscini senza ammazzarmi...
Cavo lungo 2 metri, GRAZIE.
speriamo bene per il test.
F
13-11-2013 15:57
francesco72 Offline
Messaggio: #236
tetescio: la mia intenzione è dispedirlo a chi ne fa richiesta al costo vivo dei componenti e, forse (spero di no), dell'assemblaggio. In ogni caso, giusto per dare una soglia limite, non potrà mai costare più di 30 Euro ... a esagerare.
13-11-2013 19:51
andante Offline
Registrato: Jun 2009 Online
Messaggio: #237
francesco sei un eroe!
13-11-2013 20:17
tetescio Offline
Messaggio: #238
Grazie francesco,mi associo al grido di andante,fammi sapere l'esito della prova e considera come già fatta la mia richiestaBig Grin!
Viva ADVBig GrinBig Grin
B.V.
Lorenzo
13-11-2013 20:37
colibrì Offline
Messaggio: #239
Oggi ho ricevuto il Gyro da Francesco e spero di provarlo anche domani stesso, altrimenti questo fine settimana.
13-11-2013 22:55
francesco72 Offline
Messaggio: #240
Se funziona il merito è tutto del mio amico Giampiero ( detto Pico non a caso)
14-11-2013 05:48
  Revisione autopilota raymarine st4000 plus flavis 0 244 29-03-2024 00:08
  Autopilota neco Nidelfino 4 509 10-03-2024 14:27
  Ais 500 Raymarine non comunica con Raymarine E 7 Chiò 15 745 28-12-2023 15:37
  Raymarine GyroPlus 2 - manuale italiano andante 4 602 24-11-2023 16:05
  Autopilota ST1000+ e orologio Garmin nonostantetutto 1 595 14-10-2023 09:32
  problema autopilota ST6000+ type100 polohc 5 633 12-09-2023 08:47
  cinghia autopilota raymarine st6002 Gabbo85 3 586 02-09-2023 21:44
  Autopilota ST 6001 Jarami 15 4.473 05-08-2023 23:10
  autopilota disobbediente gurapa 27 4.210 22-07-2023 16:49
  allarme watch su autopilota ST 6001. silvio chiesa 3 616 21-07-2023 11:12
Utente(i) che stanno guardando questa discussione: 3 Ospite(i)
